I've only had one vacuum wiper, and it didn't work very well. Went electric. But I do have a growing fondness of simple functionality. The wipers flow too much for a vacuum storage tank to be functional.
What about using the suction side of a regular fuel pump? discharge side straight into the intake manifold. Engine vacuum would pull through the check valves. But under load the pump, well it would pump. With as inexpensive as a regular fuel pump it I would think it would be worth a shot.
I know there are electric vacuum pumps out there as well. I have seen them used in electric car conversions. Don't know if they will run at full duty cycle and be happy. They are also a bit large, noisy and expensive.
Another inexpensive vacuum pump, diesel engines. Older diesel engines were put into truck that still had vacuum stuff like HVAC systems and vacuum brakes. I remember it was a belt driven accessory on the front of the engine. Not sure what the flow would be but I suspect it should do OK. I would still put a T-fitting in the vacuum line and a check valve to the manifold. That way you still get full power on a down hill but the vacuum pump is can make the pull going up the hill.
