Vacuum wiper vac source.
Cortez
I love the vacuum wipers...really an old school feature on my 67 and I plan to keep them. I have refurbished the units but they have always run off the manifold vacuum which is not really sufficient or correct. I am curious what vacuum source people are using for the wipers. I have an efi 351. But if I could find a mechanical fuel pump with vacuum ports I suppose I could put it on just to run wipers. Thoughts?
pcf_mark
If the 351 has a mechanical pump pad I would do that. The old school pumps with the vacuum feature on tip are really tall - check that you have room for it to fit before you buy one.
You other option is an electric vacuum pump. I have heard some cars had them from the factory but I do not know which ones if you are hunting in the junk yard. But I have used one like this and they work great for power brakes.
http://www.jegs.com/i/JEGS-Performa...MIgfbI8NKg2gIVEbXACh02LQJtEAQYBSABEgIzjvD_BwE
They are a little noisy so mount it far away from the cab.
Scoop
Bronco Old Fart
Cuchara, CO
I think you are the only other person I know of that likes the vacuum wipers! I think they are cool. Currently none of my Broncos are old enough to have them and I kind of miss them. The best thing about running them off of manifold vacuum is that you get intermittent wiper function controlled by throttle position!!
Finding a fuel pump with a vacuum port is pretty difficult nowadays.
75MIKE
NE Washington
I've never had a Bronco with vacuum wipers so may be a dumb idea. Could you take a small tank like a propane torch tank drill it,install a couple fitting and use it for a vacuum "cistern"? Feed it with manifold vacuum? Or would you need a tank that would be too big? Just a thought.
I've only had one vacuum wiper, and it didn't work very well. Went electric. But I do have a growing fondness of simple functionality. The wipers flow too much for a vacuum storage tank to be functional.
What about using the suction side of a regular fuel pump? discharge side straight into the intake manifold. Engine vacuum would pull through the check valves. But under load the pump, well it would pump. With as inexpensive as a regular fuel pump it I would think it would be worth a shot.
I know there are electric vacuum pumps out there as well. I have seen them used in electric car conversions. Don't know if they will run at full duty cycle and be happy. They are also a bit large, noisy and expensive.
Another inexpensive vacuum pump, diesel engines. Older diesel engines were put into truck that still had vacuum stuff like HVAC systems and vacuum brakes. I remember it was a belt driven accessory on the front of the engine. Not sure what the flow would be but I suspect it should do OK. I would still put a T-fitting in the vacuum line and a check valve to the manifold. That way you still get full power on a down hill but the vacuum pump is can make the pull going up the hill.
jim3326
Appleturkey
I don't think an EFI would appreciate unregulated air but I may be wrong.:p
Mass air will likely be unhappy, speed density won't care.
The more I think of it the more I like the vacuum pump off a diesel idea. Put it in place of a smog pump?
Jebus
Longview, WA
Cortez
Cortez
Some good ideas folks thanks. I’ve been wondering about a canister but concerned it would build too much vacuum and wipers go 90 mph. Just thinking logically though a canister should only add volume and level out the consistency not increase the vacuum level beyond the manifold levels. If that doesn’t work then maybe the electric vacuum pump would work.
Jebus
Longview, WA
Some '70's and 80's fords had large black tomato soup cans as reservoirs for all the vacuum and temp operated early emissions fails...
The big soup can also keeps the HVAC running correctly when on the throttle.
Scoop
Bronco Old Fart
Cuchara, CO
Late 70 and early 80's had the soup cans. Later vacuum reservoirs were round plastic units that look a lot nicer and are not susceptible to rusting.
rydog1130
Technically if you had a newer wire harness you could run the power source to this unit and just flip the switch when you want wipers....eh?
blubuckaroo
Grease Monkey
Ridgefield WA
I think the vacuum wipers are far out too. It goes well with our top mounted wipers.
Mid '70s Mercedes used vacuum for everything. Even for the door locks.
I'll bet the diesel cars had electric vacuum pumps.
661buster1963
Vacuum wipers give you more head clearance on the roll cage bar as well, they sit tighter to the windshield frame. My 68 has them, they are pretty cool. Nobody believes they run on vacuum. When mine was on the road I typically used only the driver side, lack of synchronization was a problem and they would impale each other while passing a diesel rig catching a giant bow wave across the hood.
Scoop
Bronco Old Fart
Cuchara, CO
Yes, one downside is you need shorter blades so they do not interfere. I liked the ability to use just the drivers and not run the passenger side. Also I'm not sure how the Cherokee wiper blade upgrade would work on the vacuum system. The added spring force of the Cherokee arms might be too much for the vacuum motors.
Cortez
Cortez
I have the helper springs on my blades and it’s fine, haven’t tried the Cherokee conversion
