Wanted to share the following instructions to replace valve cover gasket. I pulled most of this material from multiple threads on this site. Please feel free to poke holes in it and correct me before I start my gasket project.
Valve Cover Gasket Replacement (302 Small Block)
Materials:
Valve cover washers (Valve Cover Hold Down Tabs)
Permatex HI-Tack
Torque Wrench 3 to 7 inch/lbs
Moroso 93060 gasket
Gasket Scraper
Brake cleaner
Rag
Removal:
Remove Bolts:
6 bolts
Keep stuff out of engine:
Take a clean towel, drape it over the rocker arms, and stuff it down into the head. Give it a light spray of WD and all of the crap will stick to the towel.
Clean Head gasket surface:
Gasket Scraper
Clean with brake cleaner on rag
Install:
Make sure valve cover itself is straight and flat and clean.
Apply Permatex HI-Tack to the valve cover (where gasket will sit).
Apply Permatex HI-Tack to the valve cover gasket. (valve cover side only).
Let the Hi-tack dry for a few minutes, when it's tacky, you press the pieces together and they should stick. This will allow you to make sure your gasket will not move during install
Place valve cover on header and install bolts with Valve Cover Hold Down Tabs finger tight , and add 1/2 turn. Start at center bolt of valve cover and work in a criss cross pattern.
Torque to 3 to 7 inch/lbs
Materials:
Permatex HI-Tack
Moroso 93060 gasket
Gasket Scraper
Brake cleaner
Rag
Removal:
Remove Bolts:
6 bolts
Gasket Scraper
Install:
