bubobronco
Ok, here's the situation....I installed a JD ultimate 3.5" suspension lift on my '74. Initially it was almost undriveable as caster came in at -1.5. Installed JD drop brackets and that brought it to +1.5. Still drove like crap. Uninstalled the drop brackets and went with the JD long travel radius arms which now brings the caster to +4.0. Truck handles much better and will track straight down the road at constant highway speeds. However, it will quickly pull to the right when I take my foot off the gas and pull to the left when accelerating. Also will veer toward the right when hitting road bumps, very unnerving....and it did not do this before the lift.
I did not expect new tires to fix the problem but FYI..the problem existed with the old crappy 31" tires and still does it with brand new 33" MT Baja ATZ's mounted on MT Classic Lock chrome beadlocks (sweet rims bought from a member here). I also brought air pressure down to 28 from 34psi. as suggested from another bronco guru and no help there...
Sorry about the novel here but I need some HELP!!
Ps. All steering components are original stock parts..
