vertex
I am in the process of hooking up the vehicle speed sensor VSS and I am having a strange issue. When I put the VSS into the transfer case the dashboard speedometer works fine but the computer is not getting a signal from the VSS. When I take the whole assembly out of the transfer case the in dash speedo works and the computer sees a signal from the VSS. I have the quarterhorse programmer hooked up so I can hook up my computer to the program and watch the VSS to see if it is working. Does anyone have any ideas, I am stumped.
One idea I had is that the cast iron transfer case is interfering with the sensor some how, the sensor is usually installed in an aluminum transmission.
