Rdtrip
Hi everyone. I have the 66 running and almost done now. I noticed a lot of hissing from the gas cap after running it, and I see the carb is bleeding fuel when it seems the tank has pressure. I only have the rear tank, not dual tanks. 6 cylinder engine and 3 speed manual. I'm thinking the new gas cap is not venting properly, but also noticed the new gas tank from JBG has 2 vent lines that are capped. One may be a return line but I'm using the factory mechanical FP. Should I be running a vent line somewhere up the filler neck from one of those tubes? Leave the other one capped? This does not have any emissions stuff or canister anywhere, and have no idea if it ever did. This is a new body, the 2 other broncos were used for misc parts. Neither donor vehicle had emissions either. Just trying to figure out the venting and gas tank pressurized issues. Thank you!
