Vent Window Delete????
broncoitis
Has anyone on here just gotten rid of the vent windows altogether on their trucks? Is it even possible to do? I know that I have seen it done somewhere but I wonder how much of a PITA it would be to do and make it look right!
I would Love to see one of the Vendors come out with a kit to do something like this. I think it would be a REALLY popular upgrade.
The most important reason would be a much better placement of the sideview mirrors. They could be moved further forward on the door where they would be much easier to see out of potentially. ;D
bronconut73
This is a common modification with the 67 to 72 chevy and mid 50's ford f-1 pick-ups
bknbronco
North Metro, MN
I have spoken to the guy that builds the viewfinder windshield and he has done it a couple times and is thinking of marketing them in the future.
Izzy
Texas
Check out this thread.
I am in the process of doing this myself but I don't have any pics yet or any major progress. Just the plans.
http://classicbroncos.com/forums/showthread.php?t=201328
In a nut shell, you just have to fab a smaller triangular piece in the corner and then have a customer one piece window made. You will then need some custom weather stripping put in.
Not too bad of a deal though.
DanWheeler
Kirkland, WA
I went down this road when I was re-doing my doors. The imprecise nature of the vent windows have always bothered me. My requirement was that it was a non-permanent modification. I wanted something that fit into the area just like the factory vent window assembly.
I found that 1/2" c-channel aluminum will fit perfectly into the vent window frame. The window felt piece fit perfectly into the 1/2" c-channel but the C-channel I had was not deep enough to properly hold the felt piece.
I was going to use plexi-glass and secure it into the c-channel with foam/rubber weatherstripping.
I ended up scrapping the project and just doing a little restoration of the vent windows. They work perfectly now... as long as I keep them closed. But thats all I care about - I was just trying to solve the noise and leaking issues on the highway which is all good now.
broncoitis
broncoitis
This seems to be possible! Hmmmm. Wish somebody that has done this would chime in here.
bknbronco
North Metro, MN
Its been done dozens of time but nobody has ever documanted there work. You have to make the glass smaller than the inside braces but that dont seem like a problem. Id like to know where you can get the felt seals, the rest seems pretty simple and mostly cosmetic.
nabes68
Yuba city
My dad did this to my 55 Chevy truck. Unless you have a/c I would not recommend it. I get no air flow into the cab of my truck but maybe a bronco might be better
