I have been trying to track down and fix a vibration that is coming from the back of my Bronco.
I can only start to feel it at speeds over 50 MPH. I had a bent axel flange and thought that replacing the axel would have fixed the problem but no luck.
Here is what I have:
77 9" with a Lockrite locker and 4.11 gears
6 degree pinion shim to get a better drive shaft alignment
3.5" lift
Balanced wheels
Balanced driveshaft with new U-joints
The vibration goes away when I let off the gas and seams to go away at about 70 MPH but I think it’s just a harmonic thing at that speed.
I am thinking the old 4.11 gears that were used in my rear may need replacing or perhaps the lift stretched my stock driveshaft out far enough to cause this.
Just looking for ideas. Thanks.
3.5" lift
Balanced wheels
