Vin and Title issue
enesset
NorCal & Iowa
Guys, I'm looking for some advice/insight.
9 months or so ago, I bought an EB and the guy told me "its a 1968 but the title shows 1969".
Well I used the Brocohio Vin Decoder and sure enough it has an April 1968 build date but the Title shows it as a 1969.
Is there anyway I could find out if an april 1968 built truck was considered a 1969 model?
The rest of the Vin checks out from a color and 289 V8, etc perspective.
Thanks for the help in advance, -- Eric Ames, IA
commoncold
Its probably going to be a 1969, I can't be 100% on that but mine is a 74 and was built on september 1973.
needabronco
Prescott/Farmington
Build dates aren't always the year they are titled as but yes your generally right. I'm working on a rig that the owner says is a 74', but is a 70' by VIN, oh what fun we create right???
67PONY
SE Missouri
I thought that the cutover month from one model year to the next was August. That is how the VIN decoder shows it.
Does the VIN on the body match the one on the frame? If it does, I would guess that it's titled incorrectly.
johnmlebel
not always the case I have seen vehicles with april months be the next year a few times. all depends on what happens to it in the factory or what options end up on it sometimes
welndmn
Ford does not have standards on anything.
Really, if your vin on the frame, matches the glove box, matches your DMV, then your golden.
byson1
Nashville
And if you have removeable door frames that's a good sign of a 68 too-as that was the last model year they were offered.
67PONY
SE Missouri
I understand what you're saying, but April '68 seems a bit early to be producing a '69 model.
I am by no means claiming to know what I'm talking about though... ;D
bluebronco69
Damascas, OR
but if that 68 sat on the lot for a long time, and didnt get sold until 69 the title would then be for a 69 right? maybe?
I have seen March build dates for the following model year on Fords.
Other makes I have seen Feburary build dates.
Right now the 2010s are in the pipeline. I know of a couple 2010s that have all there preproduction items finilized and are ready for production. And yes I realize it is only mid January 2009.
Anyone who says the next model year always starts in the month of ...
Is completely ignorant of how the system works and you should agree with them or there feelings will be hurt, but ignore there advise as it is wrong.
turbotim2
____________
My guess is 68 where it still has the 289. 69 was the first year of the 302. And as asked before, does it have removable window frames? Even if it sat on the lot for a long time, the year does not change based on when it was sold. Another thing that happens is manufacturers will release a mid year model or "68-1/2" model year and certain DMV's will just make it a 69 or 68 without the "1/2" depending on their rules.
RedRider145
It must be an Iowa thing. I have a 76 and it says 77 on my title. I purchased the bronco from the original owner who said he bought it new in april of 77 from Dewey Ford in Des Moines. Mine is definitely a 76 cause it doesn't have fuel doors and according to the vin decoder it was built in january of 76.
turbotim2
____________
Now that I think about it, some manufacturers were allowed to re VIN leftover vehicles from previous model years that weren't sold. I don't think that happens these days. They have the 2008 leftovers for great deals right now. My brother picked up an 08 F250 King Ranch diesel for a steal!
67PONY
SE Missouri
So we should let the ignorant remain ignorant, if it means hurting their feelings? :)
enesset
enesset
NorCal & Iowa
I'm ignorant on what the removable window or door looks like that a few of you have mentioned. I can tell you that the strap holding my door on is not an "easily removable" ....I'd have to remove some bolts to remove the strap and thus the door. In addition, the door metal and window metal are "one and the same".
I will have to crawl around and look for the chassis vin to assure that it matches.
As a side note, this bronco forum is really great and I appreciate everyone's insights. -- Eric
67PONY
SE Missouri
You will see bolts on the front and rear of the door (at the jamb and post) that hold the window frame in on the 66-68 model doors.
These types of identifiers aren't always telling of the true model year though, because some early production broncos of any year may have items carried over from the prior year. My '67 for instance has several stock items that some folks consider "'66 only".
malonejy
My Ford Contour has a build date of May 21, 1997 and it's a 1998.
Slight hijack but will 66-68 doors fit older years?
