VIN Decoded on 1966 Bronco Please?
lindalou1961
Springfield
Could someone tell me about my 1966 VIN?
It is in my garage? I don’t know how to put a picture on the thread?
Thanks in advance
Linda
ared77
Become a contributor to post pics...money well spent!
You could also type the VIN and other codes and we'll try to help.
fatboy
Glad to be here.
New Hampshire
Linda,
If you go to the top of this thread list under stickies you will see a thread called “How to upload photos”
As for your VIN, here it is from your garage:
Plenary of folks on here good at deciding!
okie4570
NW OK
66 half cab with a 6cyl built in 1/66', Caribbean turquoise, bench seat, small bearing 9" rear with limited slip 4.11 gears. St. Louis sales area with a special order number, most likely for 16" wheels.
Great, thanks! Now we get to see pictures of your rig sometime. Doesn’t matter if it’s pristine and almost brand, new, or in pieces in the garage waiting to go back together. We love pics!
And we were just talking about factory option of 16 inch wheels last week.
Too bad you can’t get a Marti report on a 66.
L
lindalou1961
Springfield
Hi all. So I’m going to try to post some pics. Bear with me please
L
lindalou1961
Springfield
And a few more
okie4570
NW OK
I have that same or similar red horn setup in my 66 u14 lol. Cant' remember if it has two or three horns.
Great! Thanks for the pictures. And just as much, thanks for becoming a contributor and helping to keep the site as good as it is.
I see yours didn’t get the radio box checked when the original order went through.
Not a lot of them still have a blank dash without a big hole hacked in it.
So even without a radio that’s kind of lucky.
Loud can be good sometimes.
What I did with my original airhorn setup, was put a toggle switch under the dash, allowing me to switch back-and-forth between standard and air horns.
It was in my first car, but I did the same thing to the bronco later. The toggle switch was simply to swap between the standard electric horn in one position and the auxiliary air horns in the other.
Most of the time I left it switched to the original horn, but when I really needed something to get attention, or have fun with, I switched it over to airhorns.
L
lindalou1961
Springfield
This one is wired the same. I have a switch near the 3 horns that I can flip on or off
Be nice if it was at least in the passenger compartment where you could reach it. That way you could choose which one at any time.
