Vin ID progress
Cmaxx252
Bakersfield
I recently acquired a 1972 Bronco that has been in the family. I referenced the broncohio page to fill in most of the info. Does this look right? I've seen a few of the past comments on the model U151 not having info. Also, what does the body code actually represent? Half cab ect?
https://flic.kr/p/2pgXHiM
Thanks,
Cody
We have several VIN expert members here, so you should get all your details filled in pretty quickly, I would think.
The body code has more information than that in fact. The actual type of bronco, whether roadster, Pickup, or wagon, is strictly in the prefix. a U13 is a roadster, U14 is a half cab/pickup, and a U15 is a wagon.
151 helps to designate whether it’s got the light or heavy duty package in some cases.
I’m not 100% sure on that, but others will fill in all the gaps.
okie4570
NW OK
72' wagon with a 302, manual transmission built in 10/71'.
R is Sequoia Brown Poly
Small bearing 9" rear with 4.11 open gears/Dana 44 in the front
34 is for Parchment rosette front buckets and rear seat. The other things you have are correct.
