I was gonna suggest clamping a piece of speaker wire in the positive battery post cable end and running it to the gauge through any hole in the firewall.
But Nick's suggestion is probably better.![]()
don't forget to use at least 3 wire nuts and 2 twist and tape connections there bill.![]()
bill ou need to get one of those inexpensive (note i did not say cheap to possibly offend you) solar chargers to keep the battery topped off. it can double as a drink holder on your dash... simplicity for 20 bucks...![]()
Just make sure you use the "source" voltage as Nick's mentioned not the regulated.
All the wires are green. No confusing color differences.
Maybe it's time to have the old eyes checked?
pshaw. I used to work with complex warhead wiring and wrote many EOD instructions. For example:
1. Take out the 6 screws and remove the cover.
2. Locate and cut the red wire.
3. Do not cut the red wire before you cut the blue wire.
4....
Because you would getWhy couldn't you come out of the IVR?
The IVR is a pulsed output, that averages ~5V. You want a volt meter to read system voltage, not gauge voltage.Good voltage, crap it's dead,
good voltage, crap it's dead,
good voltage, crap it's dead![]()
