Warn Hub install question. Pics attached.
Nickm1024cobra
Chicago Burbs
Currently I am trying to get the pinion angle setup for the rear and need to get it right before ordering a rear driveshaft. In the meantime I had a "professional" shop regear the front.
Was just cruising around on the front (taking it easy, just a little sunshine for the wife and I) and the front started grinding and I lost all gears out front of the neighborhood. Finally got enough engagement to limp it home. Figured out the left hub was not fully locking and just banging around causing no power to the front.
Found out the outer spline ring on the waran premium shows two different install pics. Im out the cost of gear lube for popping the tcase and diff open. Could be worse.
"Pro" installed like this pic. See how the outer ring has the flat side up?
Second pic I found shows the indented side up. I flipped them this way and now have strong engagement when locked. It seems you can put them in backwards. Any thoughts? Hope I'm on the right track.
ryan97
Richmond
Just installed a set of these myself. Have not had any issues but will keep you posted.
Did they disassemble them for some reason? They are usually delivered in the box fully assembled (the inner part) and all you have to do is slide them in, install the clip(s) and then install the outer knob assembly with the six capscrews.
So basically just 2 parts to install.
If that's how yours were delivered, then either Warn put them in backwards at the factory or your guy disassembled them when not needed.
