warn lockout hub installation - New pics added
Brewmover
Tulsa
I have run into a problem reinstalling the warn hubs in my 1977 dana 44 front axle assembly. When I install the lockout gear mechanism the axle shaft does not stick out far enough for me to install the snap ring. I have pushed it forward from behind the buckle but it still does not extend far enough (it is close however).
Here is the axle assembly order I followed:
1. reinstalled the axle shafts
2. installed the rubber seal washers to the end of each outer axle segment. I believe these are referred to as the spinal seal assembly.
3.installed the caliper holder bracket, dust shield and spindle to knuckle.
4. installed hub assembly (hud and brake rotor with inner bearing and seal)
5. installed outer wheel bearing
6. installed inner hub ring and torqued to 50 ft/lbs and backed off 90 degrees
7. installed lock ring
8. Installed outer hub ring and torqued to 70ft/lbs
9. installed warn gear mechanism seems to seat all the way
10. threw hands in the air and said wtf when I could not install the axle shaft snap ring!
What did I do wrong. It seems like it is really close to going back together, but something is just right quite there.
B
Brewmover
Tulsa
Maybe a picture will help you guys solve this for me!
Steve83
This might be what you have:
...now that you've posted a pic...
It's too close-up for us to see what you've got. Back off, and don't be shy about posting 20 pics if necessary. Extra pics don't hurt.
B
Brewmover
Tulsa
This I what I referred to as a caliper bracket.
B
Brewmover
Tulsa
I have taken this thing apart twice now and I think it was assembled correctly, but the snap ring still will not go on. Could I have mixed up the outer axles when I relpaced the joints? I was not real careful to keep them separated as I thought the outer axles were the same length. I am fairly certain they are the same as the parts catalogues online do not specify a driver or passenger outer... Would really like to get this assembled before the sun goes down. Can anyone offer some advice.
savage
Bronco Nut
Renton
Did you put a bar or screwdriver on the axle joint from behind, to push the axle into the hub?
stlbl
I could be completely wrong but I feel like this is a common issue with some of the brake conversions and hub combos. Someone smarter than me will chime in I'm sure but I don't think this is a panic situation
Steve83
I realized after I posted that some '77s did come with front disks - that's why I edited it out. Is yours factory disk, or some conversion?
Yes, those pics are slightly better, but they still don't show us how the hub or knuckle is put together. Pics behind the brake shield & inside the hub (without the lock) might help. What work did you do BEFORE attempting to reassemble the hub? IOW: why did you take it apart to begin with?
B
Brewmover
Tulsa
factory disc brake setup. started out just replacing the brakes and wound up completely rebuilding the axle. there is nothing inside the hub other than the wheel bearing and adjustment nut, lock ring, and nut.
ugly74
Bronco abuser
Colorado
It's not just you....the snap ring won't go back on with the warn hubs. It's typical and It isn't critical, so don't sweat it too much.
JohnJohn
Richmond
Did you install new spindle bearings?
If the spindle bearings are not installed the correct depth it can cause the small rubber spindle bearing seal and plastic seal ring to stick out enough to prevent the axle from moving out that last 1/16". It happened to me on my 77 when I rebuilt the D44.
On another occasion I once installed drum hub seals on the back of my disk spindles and could not get the snap ring on. I had to pull everything apart and rip the new hub seal out to get the room I needed.
Bhull
White Lake, MI
I recently rebuilt my front Dana 44 with warn hubs and had the same issue, snap ring would not fit, only on one side though. I ended up having to pry the axle outward a bit inside the axle tube opening, to get the snap ring to go in. It was there before, so I knew it had to go in.
Do you have any play in the axle at all? maybe the plastic seal spacer in backwards? The axle cannot really go anywhere, but I would think there is a way to get the snap ring in. Would feel like something is wrong if it cannot. And better to find it/fix it now, than on the side of the road somewhere in the middle of nowhere. ;)
B
Brewmover
Tulsa
The plastic spacer seal is in correctly. I thought this might be the issue when I tore it down a third time last night! I am going to try and pry it forward with a ratchet strap. Maybe I just need to compress the plastic spacer. Like you said it was on there when I took it apart so it HAS to go back together!
B
Brewmover
Tulsa
Ok so the axle was protruding out the spindle as far as it would go (i used a ratchet strap and put a lot of pressure on it so I am confident it would not go any farther). I am posting up more pics to help with the diagnoses. The snap ring was on before I disassembled it so surely it will go back on!
As I mentioned in my first post I torqued the adjusting nut to 50ft/lbs and then backed it off 90 degrees. This spec is from my haynes manual which lists the process for installing the ford locking mechanism. I figured it would be the same. Any tighter and I was afraid the wheel would not spin freely. Could it be that the Warn requires the adjusting nut to be set deeper than the stock part? Does it look like I am using the correct seals on the outer axle shaft? I am about a 1/16 to 1/8 of an inch shy of having the snap ring exposed.
EricLar80
I just replaced mine a couple weeks ago. I had to grab the tip of the axle with some needle nose pliers and pull it out in order to put the clip on. Pushing from behind would also work, and is probably preferred.
Eric
JohnJohn
Richmond
I believe the plastic sealing ring is backwards. It has a bevel on the inside lip that should face the spindle. Do you have a pic of the small rubber cup shaped seal that sits on the inner spindle bearing?
The small rubber cup shaped seal should sit flush with the face of the spindle.
B
Brewmover
Tulsa
here is the seal. it is not sitting flush with the spindle. protrudes slightly.
JohnJohn
Richmond
it looks like your spindle bearing needs to be pushed in 1/16" to get that rubber seal flush. i also gave you bad info on the plastic ring. you had it correct with the bevel facing the axle not the spindle.
Well first off, this has been a known issue ever since Warn first came out with their current design lockout. Apparently they based it on some form of GM-based Dana/Spicer axle, but as far as our Ford based Dana/Spicer axles are concerned (with their different snap-ring location and spindle length), you will NOT be able to reinstall the snap ring on about 95% (or more) of the installations.
This is true for both the stock Ford disc and drum brakes, as well as aftermarket kits.
It's common, and not much can be done to make it work short of widening the snap ring groove or grinding off the end of the spindle.
Some axle shafts do have the threaded holes in their ends, and many have used a short bolt and wide washer to be a limiter, but I'm not sure how much that exactly helps, since the distance between the end of the axle (washer) and the edge of the spindle can be greater than it would have otherwise been with the stock snap ring.
The good news is that even though this was obviously a design factor from the axle company, and even with thousands of us running without the snap ring, nobody that I've heard of has ever had an issue with axle float or with any damage that could be equated to be from the missing snap ring.
Unless some of the many busted up Warn hubs were due to this quirk that is. Lots of those to report, but no hard answer as to what caused it other than too much power trying to turn too large of a tire with too much traction!
We've talked about this with Warn until we're blue in the face (though not for years now) and so after this many years of production we're not likely to see any changes anytime soon.
I'd love to see a Ford-specific set of Warn hubs that are machined slightly in that area of aluminum that falls over the spindle edge.
To your inner spindle bearing seal issue Brew, can you verify that the bearing is seated all the way? It doesn't look like it from here, but I've heard before where they were and did not look like it.
They're tight, so it might take a couple of smacks with the proper tools to see if it will go in farther.
To my mind, the rear seal should sit roughly flush. If not perfectly flush or sub-level, at least not sticking as far out as yours is.
Here again, I don't know if this is a critical measurement or not, and it's not likely to fix your issue with the snap ring (though it could if you're one of the lucky 5% or so that fit) but it wouldn't hurt it to be in the proper place if it's not yet fully seated.
Good luck.
