marty
ok so i purchased a set of e-street heads back in august of 2009. i did not start using them until 2010 because i was in the process of my efi build but they where used on my freshly rebuilt 302 with a b-303 cam. ok so since i installed everything i have not been satisfied with how the valvetrain sounded. i was using summit brand full roller rockers that look just like crane, motorsports, etc. so i called edelbrock and they told me it could be the roller bearing backlash that i am hearing and to try changing them to maybe the comp cams steel roller tip rockers they might be quieter. well i did that and it got a little better but not all gone. now i know that they will be a little noisier than factory but this seemed a bit more than normal. well the other night coming home from with dinner i had a problem. i got a bang and extreme backfiring through the intake. i knew right away it was a exhaust valve issue. so i pulled the intake and the rocker cover and lo and behold found a rocker arm stud broke right in half. ok so i inspect things like pushrod, rocker, etc. for damage and find nothing everthing is good. my rocker geomtry is spot on could not be better and i am using 1.6 ratio rockers. so next day get on the phone with edelbrock and the guy seemed a bit to the point with me and agreeded to send me one stud. i asked questions if there was any problem with theses studs but was not trying to start a arguement with him just wanted some new studs. i am afraid now that more are going to do the same. the one that failed looked like it had a flaw in it. so yesterday i come home and there is the new stud open it up and it is different from the one i had. first thing is the hex part of the stud went from 5/8 socket size to 11/16. the part that threads into the head is one to two threads longer and the shoulder where the rocker fulcrum rides is a bit longer. and there is a small radius where the sthe shank meets the hex part and the original has none. so i called them back and i explain to the guy on the phone my situation and he puts me on hold and comes back and says they made a change. so i proceed to tell him he needs to send me 15 more studs which he does. so moral to my long drawn story is if you are thinking of running these heads or have them just beware to check the studs. if you have the 5/8 size hex head change them out. i have a funny feeling this is where my valvetrain noise is coming from. i bet these crappy studs are flexing or stretching with heat and such. i asked the guy if you already have studs made for the other type of heads you sell why would you use another type in these. he couldn't answer that question. i don't understand why companies build stuff and have a good success with it and build a new product and change to a different material and risk having failures and getting a bad rep. if you already have these made just use what you know works is the way i look at it. sorry for the long rant.
