- Apr 3, 2022
- 445
I've installed a lot of weather stripping over the years. Learned early on the right way to apply the 3m adhesive. Thin layer on metal, thin layer on rubber, allow to tack, then another thin layer on either rubber or metal and attach. No mess. I even apply two strips of tape with a 5/16 gap between them on the metal side so I can apply the adhesive then remove the tape for a nice line that does not show after rubber is in place. HOWEVER...
I saw some weather stripping for a different vehicle that has the 3m double sided tape on the adhesion side. The red tape is similar to the 3m emblem tape if not the exact same stuff. Simply peel the red backing and put in place...no mess, no glue. However, do not see where it is available yet for our Broncos. But, why couldn't we get 5/16" 3m double sided tape and put it down on the metal (say in the door opening) and then carefully apply the rubber to it. No mess, no adhesive, and if you've ever put rubber on the 3m tape, the rubber will rip apart before it comes unstuck from the tape. You would not see the tape at all and the rubber would be very much stuck in place.
Thoughts?
Thoughts?
