DC_Gearhead
- Dec 28, 2015
- 570
Has anyone tried putting a wedge shim under the front spring to make them align better after a lift? I’ve been looking at my crooked springs for a while and it annoys me. I have a 3” lift. Well I was rebuilding and regearing my front diff and decided to check my pinion angles on front and back. It was a good time since I was rebuilding my drive shafts and axles too. Well my rear was 10 degrees so I bought a 4 pack of 7 degree shims to get my rearend to fix that, then when putting my front in back together I had the idea to cut up one of those extra 7 degree shims to put under my spring cup. They were $4/each.
Does anyone see any issues with that? I cut the shim to cover the flat part where the cup sits, so it seems like it would work. The surface is pretty flat, but I was thinking i would grind /file it flat as well.
Pics of my idea and my beautiful drive shafts. People really underestimate how much of a PITA it is to rebuild those drive shafts with the carden joint.
Sent from my iPad using Tapatalk
