Looks like the standard GM conversion. The Ford 5-bolt is standard fare on '76-'79 Broncos/F150's, as we figured.
The other one could be something from a Jeep or other, but it's looking like a standard conversion on stock drum brake knuckles from here.
Meaning, as mentioned previously, you can simply swap everything from the knuckles/ball-joints outward.
The rotor and hub is standard Ford on both. Even the bearings interchange if I'm not mistaken.
Knuckles are standard Ford drum brake.
Only the calipers, caliper brackets, spindles and hoses are GM-based.
Ball-joints are the same for both.
So you have just about everything you need, if you decide you still want to swap the brakes over.
Personally, I prefer the Ford design. But the GM calipers use larger pistons, which is a distinct advantage for some. The pads and parts are ubiquitous. The pin design is more common and more popular with some. I just never had any issue with the sliders, as long as they were maintained (and all of mine have always been) and have seen just as many issues pop up with the pin design as the other.
