Welding prices
Wingo4x4
Myrtle Beach
I purchased an Extreme Custom Fabrication family roll cage and when talking to the guy that normally works on my bronco, he said it be about $100 per weld point. Is this expensive? That's well over $1,000 for the whole cage.
Side note: is there any difference in the over the shoulder seat belts sold by Wild Horse and Tom's?
doghows72
Ouch, sounds way expensive to me. Most shops charge about $80 per hour. I would think that even if it took all day that is still only $650.
Is your guy including cut and fit of the cage too?
Wingo4x4
Wingo4x4
Myrtle Beach
He knows that the cage is almost ready to weld. May need some small adjustments. He does a really good job but I think I may want to check around. He did great job fixing up my floor boards but those were really expensive too.
67 Halfcab
Maybe he doesn't want the liability and is pricing it to discourage you without having to say no?
Bferrari
Find a welder, not a mechanic. Unless there is sonething special you are asking him to do, his estimate seems extremely high.
mortimersnerd
x4 or whatever. Unless he's TIG welding it, that's overpriced. Any competent welder can do a point in a few minutes.
LOVNBRONCOS
Tucson, Az
Sounds extremely expensive to me. Where you located. Might be able to help if your close. I have the WH shoulder belts they work great.
carmi
Oroville
As others have stated, I would say that is a pretty inflated price. But...whomever you decide to go with make sure you get a look of some of their previous work. A roll cage is only as good as the welds holding it together. The last thing you want is a bunch of cold lapped buggers all over your cage. And while that price may be high, It would be at least that to have the welds ground out and re-done.
wepuckett
Wow nice our first that I know of at least in Myrtle Beach, picked a Bronco project up from down there this summer. We have some people on here and on CB4x4.com that are from Columbia, and Charleston, SC. Those are the closest bronco folks I know of too you.
Wyflyer
Yep that's too high. Visit with him again, make sure it wasn't misstated.
I installed a skylight kit and steel stringers on my airplane. I tacked it all up then hired a guy to finish TIG welding it all up. This was skilled TIG welding of 3/8" .032 wall 4130 tubing. His fee was 500.00 for 8 hours. I've never seen anyone charge by the weld?
It's always by the hour.
Timmy390
Conway, AR
Agree ^^^^^^^^
$100 per weld is just crazy talk. Per weld...Really? So a 6 inch weld cost the same as a 1 inch weld?
Find a welding shop and talk to them directly.
Tim
g8rb8t
Mine was welder by a rock crawling place for $300. Granted I paid $100 for the cut and tacked version from Bronco Bob.
Desert Thrasher
You should be able to have an entire cage built and welded for $100 a point. That includes material, bending, notching and welding.
Wingo4x4
Wingo4x4
Myrtle Beach
I know of about 5 or 6 nice early bronco drivers in myrtle beach. Not sure how many of them on this forum though.
