Welding winshield frame directly to cowl
rbodine
So I'm at the point in my build where we are ready to replace windshield frame. Watching bronco videos this AM I came across a restomod with windshield hinge removed and body smoothed from cowl to windshield glass. I loved it. There is no rust under the frame.
My bronco will be an A/C, dynamat, carpet.. never have the top off, etc. I have a jeep we build for that.
My question is are there any downsides to this?
Has anyone else done this, and could you post pics?
It seems like an awesome idea (less place for air to pass thru, no water intrusion, etc)
Looking forward to your responses..
AZ73
You won't be able to install a dash pad since it screws down from behind the frame, and you'll have to take up the space for the hinge and gasket or the hard top won't reach the top of the windshield. You'll also have 2 big holes in your dash where the bolts that hold the windshield up go. All that is minor stuff.
rbodine
rbodine
we thought about filling the space taken by the hinge and the gasket, didn't consider the dash pad
JB Fab
Here is one my wife did, it came out great. Replaced the hinge with .250X1 flat-bar, three passes w/ TIG......
rbodine
rbodine
Yes, thats what i wanted to see. That looks really good. Did you run into any problems on the inside? How about mounting the dash?
rbodine
rbodine
better be sure angle is correct for doors and hardtop...
I was thinking about that? Do you think I should sort of take a poll and have people measure the angle or just line it up with the doors and the top on and go from there
EricLar80
This is a tough angle to measure and transfer correctly - need to have a good datum and measure in reference to that.
bolt the top on before you weld it as the hinge is a compromise for the top bolt holes.
JB Fab
No problem mounting the dash (no dash pad), the inside supports were welded too.
rbodine
rbodine
wow that center console is ridiculous! in a good way of course
JB Fab
Make sure you can get your roll bar in too..... Ooops!
