Welp, she died
CG
StanWOOD, WA
Went to go to my house about 4 blocks from here (at moms housesitting) and as I rounded the corner 2 blocks from my house, it died. I am thinking fuel pump or filter...IT felt like it does when it runs out of gas...but I had half a tank. I'm not so pissed that it died, I'm just pissed it died in the GHETTO!! I hope it's still all in one piece when I get to it with my friend to tow it hom in 35 minutes :(<br>Pray for my parts to be intact!!<br><br> :'(
Jeep Slayer
fort Mohave
The way you said that it died ( like it ran out of gas)<br>sounds like what hppened to me I thought the same thing like fule , terned out to be the coil that died. just something for you to think about ?:?<br>Good luck
jcmessing
Before you check the coil spray some carb spray in the carb if it starts and runs and then cuts out you have a fuel system problem.
CG
CG
StanWOOD, WA
I got her towed home...that was scary!! :eek:<br><br>I just woke up here at 1:30pm.. I was tired. :p<br>I'll head home in a few after a shower and see what the hell is up...with my luck, she will start right up :(
T
teknalee
Guest
it happens.. (happened to me alot :mad: ) but the more you HAVE to work on it the more you learn :p
mxpaz
KC
Get a hammer and use the handle and beat on your ignition mod. box.
