ntsqd
heratic car camper
With the taper of OE TRE's there's no need to worry about any wiggle since tightening the nut pulls it all to zero clearance, but with SRE's the ONLY thing that keeps things from moving relative to each other is the torque on the thru-bolt. A tight fit is still a good idea. The bolt should be mic'd and then the holes reamed to maybe as much as .002" oversize. Make the holes exactly the same and it's a hammer fit that doesn't actually solve all of the problem. The bolt should be at least a Grade 8 and I'd suggest it be a "Grade 9" or an AN bolt torqued to max spec.
Missed that the spacer is stacked washers too, agree that needs to become one piece, and one of those washers be moved to below the SRE to become a Safety Washer.
Either the drag link needs to be shorter or the trac-bar needs to be longer. Parallel only works with same length. If they're going to be different lengths then I suggest laying out the arrangement on the shop floor and moving the end frame positions until the arcs of the travel of the axle mounted ends be nearly identical. Can use a string and sidewalk chalk for this. Focus on the range of 1" down travel to maybe as much as 3" of up travel. Outside of that region the arcs will be hopelessly going in different directions, but for highway driving that range is where it'll mostly be operating.
