WH direct fit column
67 Halfcab
Bronco background: '67, AAW wiring harness installed, factory power steering box installed, want to run a '75-'77 steering wheel.
I'm getting ready to pull the trigger on an Ididit column from Wild Horses and have a question. What is the difference between the 74-75 and 76-77 models? Will either work, or will one work better?
rguest3
The only difference is the wiring I believe. Maybe just wire colors. There is a column switch diagram install page on WH website. This will show you the differences between the columns.
I recently installed the direct fit ididit into my 69 Bronco and it was easy and straight forward.
