WH Direct Fit Tilt Column
greatguy57078
I have emailed WH twice now and no reply as of yet. I have a '68 Bronco I was thinking of installing one of these "direct fit" columns in. All I see is '74 - '75 and '76 -'77. Does that mean that it would still plug into my '68 wiring? %)
Hey greatguy, sorry you haven't received a reply yet. Something must be wrong, because we usually make a fairly valiant effort to reply to inquiries as quickly as we can. Just checked my inbox, and it hasn't been re-directed there, so I'll double check the system on Monday.
In the meantime, the quick answer to your question is, NO, it won't just plug in. To either the wiring OR to the steering box, in your case.
That's why it's listed specifically for the '74 and later models (I think it's not listed for '73's with power, due to the hazard switch still being in the dash that year).
It'll physically fit your '68, but it's definitely not plug-n-play for the early models.
It's spelled out in the install video that's linked right there at the top of the Ididit Column Page on our site (should be the same video as seen on YouTube), so you might want to check that out anyway, just to see if it's something you'd want to do.
I'm going to put one in my '71, but I'm already changing everything anyway. So no stock shaft or wiring harness.
Basically, the column plug on yours is different from the later one. Not a big deal if you're comfortable with some light adapting of some wiring.
And, as mentioned, the new columns have the later turn-signal switch with the integrated hazard switch. So the wiring is different, as yours is on the dash, and this one has it right on the side of the column.
And you'd need to purchase the lower shaft assembly to mate the column up with your existing box. Your original would have the full-length one-piece shaft, whereas the new column has the later model splined stubby. Which means you'd have to add the lower section. In the '73 and later models, they were already multi-piece shafts, so the new column can interface directly with the existing lower shafts in those later years.
That's not necessarily a big problem either, as we stock all the parts to mate the new column to just about any common box in any "normal" Bronco. But here again, it just means that it's not a direct install with no peripheral thinking needed.
Hope that helps. Check out the video anyway, when you have a few minutes to spare.
Should clear things up better than I can write it.
PaulB
greatguy57078
greatguy57078
I have the original '68 column, but already had to change the lower sector when I converted to PS. Thank you for your reply DirtDonk!
