WH Hydroboost System
Jambi
Littleton, CO
Wondering if the WH Hydroboost system is worth the money vs. piecing together a hydroboost system using the other methods that are available. I have a Super Duty HB unit on hand so I'm trying to decide if I want to go that route or get the WH system.
I'd rather not mess with having to do a lot of mods to get a system to work, and it seems like the Super Duty system requires some mods based on what I've read. I'd like a system that is as close to bolt-in as possible.
bronconut73
Well the WH and JBG hyrdoboost systems are in fact "bolt-in"
It is a lot of money....but you'll likely never need to spend that money ever again....and you will have braking power so good you will be stunned...
But read the hyrdoboost threads here first. Excellent step by step explanations. Part numbers and such as well.
Pretty easy shopping. Only hard part is making all of the AN-lines, but you can have all of those made at a hydraulic shop for nominal costs.
Some fellas here have built and installed hyrdoboost systems for a few hundred bucks by hitting the junk yards and making their own lines.
If you go WH or JBG you will be in over $900 bucks by the time your done....but they are both one hell of a great kit...can't go wrong ...it'll just make your wallet lighter.
