BRONCITIS74
- Oct 4, 2015
- 340
I have a 74 Bronco with a Wild Horses twin stick shifter. The stick on the right that controls the back wheels works fine. It shifts from N to 4Hi then up to 4Lo. The shifter on the left, that controls the front wheels, will shift from N to 4Hi, but makes a terrible "clunk" when shifting back to N. The lever won't even go into the 4Lo position. It all worked when the AX15 trans and twin stick shifter was installed. I haven't used 4wd for quite awhile and am wondering if any of you guys have experienced this. What needs to be done? Does the Dana 20 transfer case need to be rebuilt? All help is appreciated...thanks
