ntsqd
heratic car camper
If anything it's dated rather than new policy.
The thing that doesn't seem to be generally understood is that the Rancho's are adjustable because they have to be to do it all, while the mono-tubes (Bils, Fox, SAW, King, FOA, etc.) don't need to be adjusted once the shim stack inside of them is correct. They can do it all.
The trouble with the Ranchos I had was that when you made them firmer, both compression and rebound got firmer. It would have been nice to firm up the rebound without messing with the compression settings. Or adjust the compression and rebound independantly of each other.
It is my understanding that the 9k's adjustment only affects the rebound damping and not the compression damping.
This would not be so bad though, I don't think, if the actual dampening characteristics were just right for our EB's. Which it does not seem to be for me anyway. But that's why I had always wanted to try all the part numbers that were compatible with mounting and length specifications. Since they don't really publish their rates, we don't all need the same ones, and even needs vary per trip, it would be all about experimentation.
Perhaps I have it backwards, perhaps the adjuster only changes the compression valving. The person who told me this is not one to get something like that wrong (he tunes desert racing dampers), but my memory could easily be faulty.
How is the extension difference between the settings?
Wow, more info! Thanks all.
So I have a history of blowing out urethane bushings. Are these 2-piece chinese things from napa going to last a while?
I wonder if someone out there has replacement rubber bushings that are 1-piece? my original 1-piece bushings on the Duffs are hourglass shaped. If you take that Duff bushing and cut it in half where the narrow spot is then it resembles the bushings inside the Napa repair kit.
I still would like to get something close to the valving as the Duffs but without urethane bushing material. I'm thinking rubber is better. Heck, it lasted 30 years on my radius arm bushings, they were surface cracked but still working fine. Replaced them with urethane and they lasted less than 5yrs.
Replaced them again with MOOG rubber and never heard another peep out of them!![]()
