Piglet
- Mar 8, 2015
- 150
So over the weekend i stumbled into what i think was a pretty good deal on some 4.5" coil and Deaver leaf springs. my bronco is currently sitting on what i assume is a 3.5" lift but with add-a-leaf springs that are in pretty sad shape. i've been doing a ton or searching and reading and get a lot of conflicting info on what else i might need (mostly front end). i figured id try to buy most of the things i need from JBG while the still have 20% off through the Dec 20th.
my bronco is tagged but not daily driven and is going to be mainly for offroad.i plan on using f250 shock mounts in the front.
so some of the things i'm looking at are:
Adjustable Trac-Bar
4 in. Drop Pitman Arm
C-Bushing Kit, 7 degree
JBG Adjustable Drag Link
possible a Trac bar riser?
also for the rear:
Heavy Duty U-Bolt Kit
Rear Spring Shims, 6 Degree
it already looks to have extended brake lines and bump stops.
so if what i read is correct you only really need an adjustable trac bar of you are worried about the axle being perfectly centered left to right. and that a lot of ppl just run a trac bar riser with the stock trac bar.
any info or help/guidance is much appreciated. i've had it for a few months now but this is my first bronco, and i'm learning as i go. i'm probably forgetting a few things besides shocks. i just dont want to order anything i dont need, or miss out on ordering things i will.
Adjustable Trac-Bar
also for the rear:
