blankenship76
Ok, I know with a title like that you think I would have a picture, I left it at the shop.
I took the STOCK lower steering shaft out of my 76 Bronco tonight, becaue the u-joint is bad.
When I removed it there is a plastic circlular piece with 3 clips on the outside and a bearing in the middle right behind the column(its kind of a little cup). I think it needs replaced to. I thought it was the lower column bearing, but the pictures on bronco graveyard are not the same as this part.
http://broncograveyard.com/bronco/i-17062-column-bearing-lower-1976-77.html
Does anyone know the name of this part or have a link to it.
Jason
Jason
