What is this muck inside my frame?
Jc.av8r
Got the Bronco home today and getting to know her a bit more. I noticed I have a power steering pump leak that will need to be addressed, but in the process of trying to source the leak, I noticed that the inside of the front cross member of my frame is a very soggy, muddy/rusty looking muck. I got a bunch of it out but I'm not sure what it all is.
Could a long term power steering leak cause this much corrosion? Could it just be mud from previous owner (would have been 6+ years ago).
What's strange is that the truck hasn't been driven in about 4 years while the body was getting restored. I drove it for about an hour today, but this stuff was pretty saturated. The power steering leak may be fairly substantial.
Anyways.....any idea what exactly this is? Should I be concerned?
Inside this portion of frame:
You can see some of the stuff on the rim of the frame hole:
Here's the stuff. It has the consistency of really dense mud. There was quite a bit, this is everything I could get out:
This hose here on the back of my power steering pump seems to be the source of the leak:
Thanks in advance...
Someone had fun, got it filled with dirt. Add water, rust generating much. Add power steering leak, and now it is an oily, dirty, rusty muck.
01JLH
Stick a hose in the hole, wash it till water comes out clear. If metal is soft, you might want to cut out and weld in some patches. If not, Eastwood sells some frame coating that you spray inside of the frame to help prevent rust from inside of the frame.
J
Jc.av8r
Thanks guys, that's what I had hoped for. The metal is not soft, it looks fine inside there.
I'll flush the rest out with water and next maintenance job will be power steering pump replacement.
sykanr0ng
Flushing it out with water is good, but if you are going to put any kind of coating inside (which I think is an even better idea) you need to use a degreaser to get the PS fluid out.
The coating will help keep it from rusting when it gets more water in there.
spap
When I brought home my current bronco 9 years ago I stuck a hose in the frame rail and washed out Arizona dust and dirt for about 20 minutes it just kept coming and the door jams
J
Jc.av8r
Can I try to just replace this hose on the back of the pump first instead of the entire pump? It seems to be the only source of fluid leak as far as I can tell. Will a new hose and clamp do the trick maybe?
904Bronco
San Martin, CA
Yes.
It is the return line, so not as much pressure as the other side.
be sure to use PS approved hose, not gas line.
J
Jc.av8r
Yes.
Thanks. How much fluid should I expect to spill when I remove that clamp and pull the hose off?
Hotrodjohn
that return line is on the low part of the tank so almost all the fluid will come out if you let it. Pull old hose off, block the flow with your finger and put the new hose on..
the greasy mud you showed is certainly normal for these old trucks
J
Jc.av8r
Cool, thank you!
Steve83
After the PS leak is fixed, and you've washed most of it off the engine/frame; go to a coin-op car wash, and alternate between high-pressure rinse water & engine degreaser for a few minutes, blasting every angle you can get through every hole in that crossmember.
73azbronco
That crossmember is the eco -green excess power steering fluid and oil leak catch container.
