What Locker to Get???
broncoitis
I would like to get a Locker for the front axle. Currently have a Dana 44 from a 76 I believe. It will be selectable so I am considering probably 4 units:
1. ARB - Nothing to really say I guess. Pretty much the standard in terms of selectable lockers I would think. Although something more to stuff under the hood, having the compressor would probably be a good thing.
2. Ox Locker - These seem to have good reputations for the most part. Like the ARB, they are not cheap and you have to deal with the cable!
3. Zip Locker - These seem to be pretty well made with a great warranty! I guess I would say a different spin on the ARB. Haven't really priced them but probably not cheap either. I would think 950 and up?
4. E-Locker - Last option. I like the simplicity of the hookup. Anybody have anything bad to say about them? Leaning in this direction!
When I do this it is gonna require new axles up front most likely and I know that you get what you pay for and quality is not cheap.
Arikilen
Clovis, CA
The cable on the OX isn't that bad to deal with. I really like it. If you decide you don't like the cable, you can go air or electric later...
Mountain Ram
Recovering Masshole
Abingdon, VA
I am a big fan of mechanical over vacuum or electric. As for the cable, Jeeps and Dodge used vacuum actuated front axles and the #1 upgrade was a cable actuator (posi lock). I had one and never had an issue.
wgamble
Bossier City
I had Eaton lockers in a HP30 and an 8.8 on my yj running 36" TSLs. This rig was highway and a beast on the trail (believe it or not). I love me some eaton lockers, just make sure to run royal purple in the diffs if you run this locker.
matt w
I had ARB's in my Jeep. I NEVER had a problem with them.
I put an E-locker in the front of my Bronco about 6 months ago and so far it works excellently!
The reason I went with the Eaton E-Locker is because I did not want to run a compressor nor spend the money for that!
The E-Locker was less all around and from my research the newer generation is stronger.
Good Luck with your choice.
barnsbronco
I have been running the Eaton e locker for several years now with zero trouble.
krashnpa
Mounted Joy, PA
I currently have ARB and Zip lockers and have never had an issue with either except a leaking fitting on the ARB once. Maybe I'm not trying hard enough tho.
xcntrk
NOVA
I run the Eaton E-locker and couldn't be happier. You just need to make sure you engage it when the axle isn't under load otherwise you can risk damaging the engagement pins (problem with E-lockers). It's when you try to engage the thing with your foot on the throttle and an open wheel spinning that it can fail.
broncoitis
broncoitis
Thanks for the input so far from everyone! I am taking all of this in for sure. Hopefully some others will post what there thoughts are about the different options I have listed! Thanks Again! ;D
nvrstuk
PNW
Here's why I think ARB is the ultimate selectable: longevity/durability
- I bought my 1st ARB for my Dana 44 from Tom's Bronco Parts in Feb of '87. Been using the daylights out of it every since. I've gone thru at least a dozen axles in it until I upgraded to CTM joints and Superior's best axles about 10 years ago. ARB never failed when axles or joints blew all those years
- Bought my ARB for the 9" (from Tom's again) with 31 spline axles back in '96. 1st gen ARB-never failed when I lost a few axles.
- Bought my 35 spline ARB about 4 yrs ago and still no issues.
How can you go wrong with a superior, time-tested unit? Just saying, they've been around forever and don't blow up. It's YOUR fault if the air line fails. I've used the same 5mm blue air line up front without changing it since '87. Route it properly once, do it right, and don't look back...
IF you are going wheeling, you WILL lower air pressure in your tires. How will you air back up if you bought an E-locker because you didn't want the complexity of a small compressor under your hood or in the back corner of your rig?
You NEED air...
my .02, hope it helps
Have fun, go wheeling...
