What saginaw power steering pump for explorer serp and BCB vintage air setup?
Jolly Roger
I bought the BC broncos vintage air kit for the explorer serp set up. They are out of the saginaw pumps and wondering if anyone knew what saginaw pump I would need so i could source it elsewhere. I will also be running hydroboost. I found a saginaw pump at a friends shop but it would not work because the hose fittings were on the side and I had clearance issues with the innder fender wall so I would need to get a pump with fitting coming out of the back. Any help would be much appreciated.
toddz69
Are you referring to this kit?
https://bcbroncos.com/shop/steering/steering-power/48-14051-explorer-saginaw-power-steering-bracket/
with the AC compressor mounted on top of the pump?
If so, you'll need a pump like this:
https://www.wildhorses4x4.com/produ...Steering-Pump/Bronco_HD_Delphi_Steering_Pumps
and I think WH will sell you the serpentine pulley for that pump as well.
You can see how it mounts with those fittings in the picture shown here:
https://www.wildhorses4x4.com/product/19201/newproducts-EB
(WH sells the same setup that BC does).
Todd Z.
Boss Hugg
Bringing this back up because I want to make sure I understand correctly that the ac bracket and the PS pump bracket are two different pieces. Seems like it'd make sense to offer it as one piece.
CowboyGrin
the circus looks like fun
Oklahoma
I believe it’s to allow for different ac compressors. I bought the ps pump and bracket from BC but held off on the ac bracket because I haven’t figured out which direction to go on ac yet.
CowboyGrin
Oklahoma
Found it. The description says the add on ac bracket is different for York and Sanden mini:
