what size fan can you run with the factory or aftermarket shroud?the shruod on my is not off a bronco i think because it is turned upside down and will only work with a 15 inch fan.i am also changing the water pump at this time what should i go with?orealliys has a edelbrock avaliable but the only thing local is stock.
