The problem is that certain sealants can be used alone, OR with certain gaskets, but NOT with other gaskets. For instance; I'm reassembling an engine right now using steel-reinforced nitrile pan & VC gaskets. They're designed to be installed "dry", but the seam between the timing cover & block requires some liquid sealant that contacts the pan gasket. And the tips of the pan gasket that go into the pockets beside the front & rear main seals require something. I used Hylomar blue on the pockets, and E6000 for the TC seam, but silicone could be used in either location. And with other types of pan gasket, silicone would be used on the whole gasket (on the pan side only). Then there are gasket enhancements, like Copper-Coat; and gasket replacements, like RightStuff. And even silicone sealant is available in a wide variety of flavors; common, quick-cure, slow-cure, high-temperature, high-strength, oil-immersion...
So the sheer quantity of options, combinations, and substitutions I think would make a list too impractical, & subject to interpretation & style.
