Do you have manual or power steering? I assume power with that size lift (and the usual associated tires), but you can get away with more caster with power because more positive caster does tend to make it harder to steer with manual.
Anyway, a "decent" amount of Positive Caster might be 2 to 3 degrees with manual steering, and 4.5 to 6 with power. You can get away with, and some people here use, more caster than that even, but it's not specifically required.
Unless you're set up to measure your own caster (how are you at math & geometry?), the only way to tell what you need is to find out what you have. And the best way to tell what you have is to take it to an alignment shop and have them give you a full readout on what the current settings are.
I don't know if the BC arms can have too much adjustment, but if you can't take it to an alignment shop, or just don't care to go through all that, and have power steering and large tires, maybe just set the arms to their max offset and see what you end up with.
From there you can have the alignment checked and see if you're in the ballpark or not.
The biggest issue I see in doing it that way, is that the more caster correction you apply, the worse off your pinion angle is. To the point that you could literally bind the u-joint. So obviously, you have to at least look at that when you're setting it up.
If you can't get enough caster angle to achieve good road-manners without killing your u-joints, then you're going to have to cut, turn and re-weld the outer steering yokes (commonly called the "outer C's").
But you won't know until you get there. So give it a whirl.
Good luck.
