wheel problem, need help quick!!!!!
BroncGuy7710
Louisville Ky
ok heres the deal, the lug nuts on my front right tire have started to back off, ALL of them. For some reason, the studs are now spinning freely and i can't get 3 of the lug nuts off. they don't tighten or get loose, they just spin the stud. HOW DO I GET THEM OFF!:eek: :eek: ?:? ?:?
thnaks in advance
Tyler
4byford
Yucca Valley CA
I am assuming you have disc brakes.... (77) so my solution of removing the hub and wheel together to get to the back side of the stud won't work... can't get the caliper off because of the wheel.
Torch????
1975stroppebaja
That happened one time on my Ranger. I might have just been lucky, BUT I used a high speed impact wrench to get them off. I wasn't able to spin them fast enough using a regular 4-way lug wrench but the impact wrench did the trick. Good luck.
cbfomoco
WV
depening you might be able to knock the calper off with the rotor. Would be close though. it would all depend on if you can get to teh bolt that holds the slid for the claper. I dont know though. probly torch.
Jeepster
try wedging a screwdriver or something under the lugnut, as your prying up on it turn the nut.
chances are your studs are ruined now anyway.
70_Steve
Old Guy
Chisel and a BFH. Split the lug nut by driving the chisel into the lug nut parallel to the stud. Sharpen the chisel often.
Gummi Bear
Since you have exhausted all other avenues, head on over to Sears, and in the automotive gadget section, they have a 'Nut Splitter" it works pretty well, and you may well want to use it on 3 sides of the nut to get it to flare out enough to get off of the stud.
PS - this is one of the greatest tools I have, and a little more knuckle friendly than 70 Steve suggested, however the same premise.
mtn_bronco
Leadville, Colorado
You have already ruined the splines on the studs that keep them from spinning. If you can't wedge something like a screwdriver to keep the stud from spinning, you are probably going to have to cut the lug nut off or just cut the stud.
3 spinning is bad.... can't drive it anywhere for help.
Go to the auto parts store in your wife/girlfriends car and get 3 new studs.
Howard
