18" wheel problem!!!!!
SCWALKER0104
Looking to see if anyone can help me??? I ordered a 18x9 raceline wheel that has a -12 offset and 4.5 back spacing. The wheel sticks out like 3 or 4 inches. I have a 3.5 suspension lift with a 1" body lift. Was going for the lifted luber look. What offset and back spacing do I need for the wheel to fit without sticking out???
What did you have before? How did it fit? Did you swap to full width axles?
SCWALKER0104
SCWALKER0104
pm07W3Cyj
AZ73
Eyeballing it looks like less than 4.5" BS. BS is the distance from where the wheel touches your hub to the inner edge of the wheel. A 4.5" BS would be half way of a 9" wheel. I have 9" wheels with a 4.5" BS and my inside edge is much closer to my tie rods.
In reality, if you're running stock fenders, 9" is too wide a wheel to fit inside of them. And don't worry about the offset. It's a function of the back space. The more BS, the more negative offset. An 8" with a 4.5 BS should be fine.
https://www.lesschwab.com/article/what-is-wheel-offset.html
Apogee
Tangent, OR
You need to tell us the width of the wheel, since BS only tells us where the inside of the wheel will be located relative to the WMS. An 8" wheel with 0 offset will have about 4.5" BS, as the wheel width is bead to bead, not lip to lip, and the lip typically adds about 1/2" to the dimension. A 9" wide wheel with 4.5" BS has approximately +12mm offset and so forth. There are BS/offset calculators available online if you want more info.
Is the front axle a high pinion? You might have swapped axles and not know it since you have never seen it with wheels on it before,
rguest3
Looks like a standard width Bronco axle.
A 17x8.5 with 4.75" Back Spacing fits inside the rear uncut fender with a 285/70/17 with a 2 1/2" +1" lift.
With an 18x9 you will need at least 5" back spacing.
Let's back up. What size tire do you want to install?
Timmy390
Conway, AR
Were running the same setup......
Method NV 305's 17x8.5's and 4.75 backspacing with 285/70's same lift. My front fenders are NOT cut and the tires stick out less than an inch. I do rub the radius arms at full turn. Not much but they do rub.
To the OP, I'm not sure you can get the 9 inch wide rim/tire combo under the fender and not rub HARD on the radius arms. 4.75 is about as deep as you can go.
Tim
SCWALKER0104
SCWALKER0104
Thanks for all the comments!!! I'm just going to run with what I have. I bought raceline shift 18x9 -12 offset and 4.5 back spacing. The tires are Yokohama geolander M/T 285/75/18(33.9x11.2) or 275x70x18(33.1x11.2) there both on back order so the first pair that comes in is mine. My bronco is uncut with a 3.5 suspension lift 1inch body. Hope everything will be OK will post when it's done. Should have done more research this isn't the rout I was wanting to go but S#*T happeneds
Definitely!
You should measure the backspace SCWALKER. If you got the wrong wheels, then Raceline owes you a return and the correct set.
Agree. Uncut Broncos are tight even with 8's, so adding even that extra inch can make for some tight fitments.
That should be "positive" offset.
Less backspace, deeper "dish" wheel, wheel farther out, more "negative" offset. Shallower dish, more backspace, tucked in tighter, more "positive" offset.
If that's a link to your Garage, it's not working. But I checked the garage and the Bronco is looking pretty sweet!
duffymahoney
I will have my black rock yumas for sales soon (wheel is nla). 17x8-4.5 with 285/70-17s on them. 500 miles on the tires.
