Where does this wire need to go?
Fireball05
Well, it's finally happened. Someone posted an electrical question that even the great and all-knowledgeable Viperwolf can't answer!!!
Viperwolf1
electron whisperer
Oh ye, of little faith.
COLOR CIRCUIT # DESCRIPTION
BLACK 57 GROUND CIRCUIT
BLACK-GREEN 30 CONSTANT VOLTAGE UNIT AND INDICATOR LAMPS FEED
BLACK-GREEN 733 DISTRIBUTOR TO BREAKERLESS IGN MODULE
BLACK-LT BLUE STRIPE 53 COURTESY LAMP SWITCH TO COURTESY LAMP
BLACK-LT GREEN HASH 297 ACCY. FEED FROM IGNITION SWITCH
BLACK-ORANGE 25 POWER FEED TO HEADLAMP SWITCH
BLACK-RED 26 ALTERNATOR GROUND AT VOLTAGE REG
BLACK-RED 38 STARTER SOLENOID TO AMMETER
BLACK-RED 140 BACK-UP LAMP
BLACK-WHITE 28 WINDSHIELD WIPER SW. TO WINDSHIELD WIPER MOTOR
BLACK-WHITE 60 CONSTANT VOLTAGE UNIT TO GAGE
BLACK-YELLOW 37 AMMETER TO FUSEBOX, ALTERNATOR OUTPUT TO MAIN POWER IN
BLUE 932 CARBURETOR THROTTLE SOLENOID, ALSO 12V TO BREAKERLESS IGN MODULE
BLUE-YELLOW 1 HORN SWITCH TO HORN RELAY
BLUE-YELLOW 482 HORN SPEED SENSOR OVERRIDE SWITCH (NY ONLY)
BROWN 262 STARTING MOTOR RELAY TO IGN. COIL 1 TERM.
BROWN 285 HEADLAMP SW TO EXTERIOR LIGHTS
BROWN 399 HEATER BLOWER SWITCH FEED
BROWN 984 MARKER LAMP FEED
DK BLUE 56 WINDSHIELD WIPER SW. TO WINDSHIELD WIPER MOTOR
DK GREEN 282 TURN SIGNAL SW. TO RH REAR TURN SIGNAL LAMP
GREEN 614 HORN SPEED SENSOR SWITCH TO SPEED CABLE SENSOR (NY ONLY)
GREEN-BLACK 951 WASHER PUMP MOTOR FEED
GREEN-WHITE 50 LEFT HAND TURN SIGNAL INDICATOR
GREEN-YELLOW 232 COIL TO BREAKERLESS IGN MODULE
LT BLUE 44 TURN SIGNAL FLASHER TO TURN SIGNAL SWITCH
LT BLUE-RED STRIPE 19 INSTRUMENT PANEL LAMPS FEED
LT BLUE-WHITE STRIPE 40 CIGAR LIGHTER FEED
LT GREEN-BLACK STRIPE 12 HEADLAMP DIMMER SWITCH TO HIGH BEAMS
LT GREEN-RED STRIPE 904 (COIL) OR (AGCY.) TERM. OF IGN. SW. TO ALT. REG. (IGN. TERM.)
LT GREEN-WHITE STRIPE 3 LH FRONT TURN SIGNAL LAMP
LT GREEN-YELLOW STRIPE 54 INTERIOR LAMP SWITCH FEED
ORANGE 35 ALTERNATOR REGULATOR "F" TERM. TO ALTERNATOR
ORANGE 286 MAIN FUEL SENDER TO FUEL GAUGE
ORANGE-WHITE 763 WIPER POWER FEED
ORANGE-YELLOW 734 DISTRIBUTOR TO BREAKERLESS IGN MODULE
ORANGE-YELLOW STRIPE 8 TURN SIGNAL FLASHER FEED
PURPLE-BLUE 735 DISTRIBUTOR TO BREAKERLESS IGN MODULE
PURPLE-WHITE STRIPE 977 BRAKE WARNING SWITCH TO INDICATOR LAMP
RED 63 WINDSHIELD WIPER SW. TO WINDSHIELD WIPER MOTOR
RED 284 HEADLAMP SW TO STOPLIGHT SW
RED 296 HORN SPEED SENSOR SWITCH (NY ONLY)
RED-BLACK 810 STOPLAMP SW. TO TURN SIGNAL SWITCH
RED-BLACK STRIPE 13 HEADLAMP DIMMER SWITCH TO LOW BEAMS
RED-LT BLUE STRIPE 32 STARTER CONTROL, ALSO START SIGNAL TO BREAKERLESS IGN MODULE
RED-LT GREEN STRIPE 16 IGNITION SWITCH TO IGNITION COIL BATT. TERM.
RED-WHITE HASH 383 EMERGENCY WARNING FLASHER FEED
RED-WHITE STRIPE 39 TEMP. GAGE TO TEMP. SENDING UNIT
RED-YELLOW HASH 640 DISTRIBUTOR MODULATOR FEED
RED-YELLOW STRIPE 15 HEADLAMP SWITCH TO HEADLAMP DIMMER SWITCH
WHITE-BLACK STRIPE 4 ELECTRIC CHOKE TO ALTERNATOR S TERM
WHITE-BLACK STRIPE 950 WASHER CONTROL SWITCH FEED
WHITE-BLUE 49 RIGHT HAND TURN SIGNAL INDICATOR
WHITE-LT BLUE STRIPE 2 RH FRONT TURN SIGNAL LAMP
WHITE-ORANGE 58 WINDSHIELD WIPER SW. TO WINDSHIELD WIPER MOTOR
WHITE-RED HASH 385 FLASHER TO EMERGENCY WARNING SWITCH
WHITE-RED STRIPE 31 OIL PRESSURE INDICATOR TO OIL PRESSURE SENDING UNIT
YELLOW 21 IGNITION SW MAIN POWER
YELLOW 33 STARTER SOLENOID TO HORN RELAY
YELLOW 152 VOLTAGE REGULATOR FEED
YELLOW 460 COUNTRY HORN (NY ONLY)
YELLOW 994 DISTRIBUTOR VAC CONTROL VALVE
YELLOW-BLACK HASH 137 RADIO ANTENNA SWITCH FEED
YELLOW-BLACK STRIPE 283 TURN SIGNAL SW. TO LH REAR TURN SIGNAL LAMP
YELLOW-GREEN 461 CITY HORN (NY ONLY)
YELLOW-LT GREEN HASH 6 HORN RELAY TO HORN
YELLOW-WHITE STRIPE 29 FUEL GAGE TO AUX TANK FUEL GAGE SENDER
TwoDalesDad
That little wire clips on the end of the Head Cam Spoke! ...And it is directional btw...
Doyle
I think ya got it coverd Viper, good post, lol.
miikee73
Shadetree Guru
Aloha
Your all wrong....anyone can plainly see it is the wire to the Blinker Fluid reservoir. Jezzzz,lead the guy down the wrong path ...As you can see in the picture.
Blue Bastard
OP must have though he posted a pic.....probaly scared him away. OP, Don't let all the smart asses scare you off. ;D They are very helpfull. Send me a picture of the wire in question and ill post for ya.
maxcruise
maxcruise
St. Francisville
Alright, alright. It was my first post. I did get a laugh out of some of the comments though. I'll post pics when I get this site figured out... Stay tuned.
