Which micron fuel filter after carter electric fuel pump?
guidoverduci
NorCal
Most of the threads I’m seeing are EFI fuel filter related, suggesting 10 micron or less after the fuel pump. Any thoughts on a decent fuel filter after the carter electric pump for carb application? Currently running a 100 micron wix before the pump and one of those glass types in the engine compartment right before the carb.
Jdgephar
I have EFI and run one of these before my high pressure pump. It's 5 micron.
https://a.co/d/gW2OAJS
I see no reason why this couldn't also be used between your fuel pump and the carburetor. It's a stock Ford part for many cars, so they should be cheap and easy to find anywhere.
I used it with this 2 pack:
https://www.amazon.com/dp/B000E35WHO/?tag=cbama-20
Definitely get rid of that glass filter you are using. In my opinion, they are a big fire hazard. Either the glass breaks and leaks, or the cheap seals degrade and leak.
Sent from my SM-G981U using Tapatalk
