Which pilot bearing
Jaybr
Watching as I will be installing the same
If you're a machinist or have those skills you could probably take the old bronze bushing style for the Ford and machine the ID out to the proper 3550's 3/4" dimension, but that's assuming that the stock one is smaller. Which I don't remember.
Is that the one that comes with your new AX15 with adapter kit?
Y’all are bringing me one at SC
Excellent! Thanks
And yes, that's the one.
I believe that they're included in each kit, whether you get the entire clutch assembly or just the disc. It's pretty much required, but that does not mean that everything has been thought of every time!
Do you have the kit part number so I can double check?
If not, give a quick call to the office so they can look it up.
Might as well be sure you know...;)%)
Thanks. Yes, that's the full kit and the pilot bearing is included.
