Honestly not sure of the year(s), but just search on CL or FBM, you can usually find a set for a couple hundred bucks. Shop carefully, though, there are several different versions that look very similar, and even some steel wheels that look a lot like them. Good thing with Dodge/Ram is that they still use the old school 8 x 6.5" (8x165mm) bolt pattern. Inspect them carefully, for some reason a lot that I came across had a significant groove worn into them on the inside of the rim, apparently from rubbing on some suspension part. Try to grab the lugnuts, too.
