I’m going to have to challenge you on this one; not because I’m wanting to argue, but because I’m here to learn. There are plenty of people on here with more experience than me. This will help me because I have solid plans to build a set of 40 spline high pinion 609 axles with ARBs, though I’m about a year out from starting the process. And yes, I understand the inherent weaknesses of a high pinion rear axle.
The 609 exists because many think it is the best of both worlds. There are obviously many variations to this axle, but if money isn’t a concern, my understanding is that the 609 is clearly better than a Dana 60 (or at least comparable) when built with the best components.
I agree that the ARB is the weak link, but the competition ARB is an improved design with improved materials. It is much better than the standard ARB, and is used on a 10 inch ring gear with 40 spline shafts. Even Dynatrac doesn’t recommend 40 spline shafts for the ProRock 60 because it makes the ring gear the weak link. My understanding is that a 609 10 inch ring gear is stronger than a Dana 60 ring gear, and that the 609 competition ARB, though weaker than a Dana 60 ARB, is still strong enough for heavy competition use. Please explain if you feel otherwise.
Also, I’d really like to understand how you think a 609 is difficult to seal, if you could please elaborate. Thank you.
There’s nothing wrong with a 9”/609 in a racer, in fact it’s my preference. In a racer your in them all the time inspecting parts between races, much simpler with a 9”. Also makes swapping broken parts in the pits easier. As for sealing the Seals-it seals are great, simple and easy to change. They hold up quite well, way better long term that most would imagine. Gear Works parts are simply amazingly strong, but designed for a racer, they can’t tell you the longevity of their gears because they don’t really know, but I do know if a few with 20,000+ race miles on them. In other axles with similar metallurgy they wear out after 6-10,000 miles.
To me the bigger debate is the 40 spline axles. We found that we broke more driveline parts with 40 spline than with 300m 35 spline. It’s simple physics, the 35 spline has some give like a torsion bar soaking up shock loads, 40 spline is stiffer sending those impacts up the drivetrain. So unless you’re pushing 800+ HP in a trophy truck or rock bouncer I have a hard time justifying them. 40 spline axles eat 9” progears with 35 spline ponions for a light snack with 500HP. But they live very happily with 35 spline axles. 40 spline aren’t recommended for D60 because of the shock load, the pinion can’t take it.
As for brute strength, in a FRONT. Gear works high pinion hands down all day long, second is hi9. imo a std 9 is right close to a high pinion 60, failures are about equal. In all 3, hi9, std 9, and D60 the pinion is the weak link. In the hi9 and std 9 the pinion shaft twists off, in the std 9 sometimes you’ll brake the gear, just depends, 60 always brakes the gear. if you throw the cash to 10”stuff your down to the differential, even with the competition ARB and why you normally see spools in them.
IMO the 10” stuff is better than an 80 in the rear of a racer, it’s lighter. I even prefer a 14bolt over the 80 for the same reasons. D60’s in the rear are tough, and imo will hang with a 9” only because the 28 spline pinion gives up about the same time as the ring gear on the 60, depending on gear ratio, get past 4.88:1 the 9” begins to gain advantage the deeper you go.
@bax you can affordably get any length axle shaft you want, but James is right, packaging becomes th issue. I’ve built 3 59” wide 60’s and it is just a can of worms. Wound up redoing 2 of the 3, one to 61” and one to 64” the other they made it work but had to change a lot of stuff to make it fit.
So comes down to are you building a trail truck on a modest budget or let it all hang out and build what you want because it’s what you want, by all means I’m for doing what makes your truck yours, you’ll be happy.
I’ve left out the latest crop of super duty axles, get one of those and throw a locker in it and call it done, 35 spline hub to locker and 1550 joints for the win, run it straight out of the box as is. They are just wide.
@1969 gave reference to this axle.
PS: when we went to 40 spline it wasn’t due to breaking 35 spline, it was a sponsor/marketing partner deal….
