65” front, 64” rearWhat’s your wms-wms ?
@Yeller has answered most of this for me. I'll let @nvrstuk tell you why the 9 inch ARB is a turd. (and eliminating the gear chamfer, adding a giant bias spring that forces it to stay engaged and calling it "competition" doesn't make it good. but it does make it better...)I’m going to have to challenge you on this one; not because I’m wanting to argue, but because I’m here to learn. There are plenty of people on here with more experience than me. This will help me because I have solid plans to build a set of 40 spline high pinion 609 axles with ARBs, though I’m about a year out from starting the process. And yes, I understand the inherent weaknesses of a high pinion rear axle.
The 609 exists because many think it is the best of both worlds. There are obviously many variations to this axle, but if money isn’t a concern, my understanding is that the 609 is clearly better than a Dana 60 (or at least comparable) when built with the best components.
I agree that the ARB is the weak link, but the competition ARB is an improved design with improved materials. It is much better than the standard ARB, and is used on a 10 inch ring gear with 40 spline shafts. Even Dynatrac doesn’t recommend 40 spline shafts for the ProRock 60 because it makes the ring and pinion the weak link. My understanding is that a 609 10 inch ring and pinion is stronger than a Dana 60 ring and pinion, and that the 609 competition ARB, though weaker than a Dana 60 ARB, is still strong enough for heavy competition use. Please explain if you feel otherwise.
Also, I’d really like to understand how you think a 609 is difficult to seal, if you could please elaborate. Thank you.
Mines a 13 bolt 1 rock at a timeShaved 14 bolt rear and shaved Dana 60 front!
I think you’ll be hard pressed to find stock width Dana 60 axles.I’d love to see some photos of a modern, stock-width Ford Dana 60 under an EB.
I’ve been wanting to see axles that wide on an EB for a long time. It actually looks pretty nice! I guess it’s a partial alternative to narrowing the body. Any downsides or regrets?I think you’ll be hard pressed to find stock width Dana 60 axles.
Here is my build thread with 08 super duty axles front and rear. 73” wms-wms
https://classicbroncos.com/forums/threads/05-super-duty-60-swap.314548/
Unfortunately with the rising prices of first generation broncos I think you’ll see less and less people modifying them and especially putting one ton axles in them. They’re all going to be street queen ice cream getters.
I will measure when I go to the shop this week and get back to you!Mine is full width, same as a king pin ford lol. 69” if memory serves me correctly. It is 81-1/2” outside of tire to outside of tire.
@1969 I should probably ask in your thread…. But since we’re discussing d60’s and full width. How wide is your front outside of tire to outside of tire?
Why would you narrow the body?I’ve been wanting to see axles that wide on an EB for a long time. It actually looks pretty nice! I guess it’s a partial alternative to narrowing the body. Any downsides or regrets?
Put the ring gears from a 30,44, and 60 all side by side as well. That
I couldn't afford two 9" TruHi9's... both in pieces after 8 yrs. 35 spline, RCV axles, RCV FF... still grenaded. Go 14 bolt.Cheaper.
Stronger.
Better driveshaft angles.
Superior traction adding differentials.
Easily upgraded to 35 spline.
Removable cover for inspection.
Cheap used gears available in 4.56.
Here’s my new 60. 35 spline ARB, chrome moly axles. 4.88’s with big bearing Explorer discs.
I couldn’t afford a 9 inch.
Are you comparing it to a 14 bolt for strength or?Yeah, but the Sterling if I remember right is lacking a pinion brg, has a longer pinion shaft (messing up DS angles) and lacking comparable pinion strength if I remember right.
You are right on. It is HARD to find anybody in my Valley to go wheeling with. Must be 9/10 guys in the big city 100 miles west of me that won't even drive in the RAIN much less go wheeling.I think you’ll be hard pressed to find stock width Dana 60 axles.
