Why do a 351w swap?
68ford
i like my 302. no need for low end torque and i shift at 7000. i like the room for my engine cage and thelightness being that i allready bend motor mounts on landings.mine makes around 350 hp and stiil gets 15-17 cruisng down the freeway at 60. iv noticed that with the shorter stroke motors you can make the power come on at the same time but they will still spin higher. maybe next time ill do a 347, but not 351, i need the room and cant add anymore weight. so you need to see what best fits your needs.
mtb_medic
los gatos, CA
Be careful if you are building a high RPM motor. we run a 410 (351w stroked) in the modified. the first two that were built for us spun mains due to improperly installed oil restrictors. these are very important they keep the oil on the crank at high RPMs.
good luck
mtkawboy
Billings Mt
I can see a stock or near stock 351, but where do you guys use the power of a 408 except to find the weak spots in the driveline? About 80 or so Is as fast as I want to go in a Bronco myself but maybe Im just getting old. I have seriously fast motorcycles if I have the need for speed. If youre going to rebuild anyway Id definetly do the 351 because the cost is the same or pretty close.
feitctaj
FNG
Group W Bench
15 years ago I coulda used a 408 for a TT racer( tavern to tavern).
Anybody that has been with me in MY EB knows that after building my 302 as a low RPM motor( 9.5 comp, zero decked , qwenched up the cyls, ballanced,forged pistons, nice low to mid cam), they know that you don't need 408 cubes to break drivelines or axles, or ujoints, or ,,,,,,, ,
but up here a 408 would make a great TT racer(tree to tree)
68ford
7000rpm regularly ;D
showphoto.php
broncnaz
More fuel for the fire. while a 351 may fit under a stock hood no body lift the stock air cleaner assembly is less than a performance piece and it probably actually takes power away and being so close to the hood I'm sure heat build up doesnt help either. Not saying it doesnt work but you know fuel for the fire.
If your worried about buring oil how about a 331 stroker comp cams 264HR cam stock heads 351hp 400ft lbs torque. If you need more than that throw on some aftermarket heads like TF or AFR and the numbers go up to about 440hp/445ft lbs
blksn8k
I may never need all the power my 393 makes but I just like knowing it's there. Must be a guy thing. This is Bob. He's got a great new swing of confidence. :eek: ;D
