- Oct 25, 2016
- 941
Hi all, yet another turn signal dilemma...
Upon installation of Centech harness and manual rebuilt steering column with replacement TS switch. Either left or right turn signal from the lever results in both front turn signals blinking.
I have swapped in my old turn signal switch but get the same results.
I have new correct bulbs in my old cleaned up turn signal buckets. I have verified that I am using the bright filament for the blinker and the weak filament for the park lights.
I have solid grounds from the headlights and TS buckets to the core support. Headlight and TS ground are attached to same threaded post on the driver and passenger side.
Hazards, headlights, tail lights all working great.
No obvious signs of exposed chafed wires touching but I suppose it’s possible somewhere.
Any ideas appreciated!
