Why would the PO do this?
j.r.nice
Why? Don't know......but I think for sure I would take the tape off the lower cross pipe just to make sure he didnt do it to make a smaller package to ship or move or...?
maybe he bought it used and the person he bought it from cut it to ship it.
msweb
Rats - I thought the first picture was of the exhaust where he cut an H pipe out... Oh well, at least it doesn't have huge hole in the exhaust - does it??
If nothin else, it's better than findin a PVC rollbar under that wrap!;D
IowaMike
Probably thought he could get a custom double tube rollbar look by piecing 2 together. In the middle of it, got lazy.
77TexasBronc
Baytown Texas
On CRACK most likely. It appears that he was wanting to do away with the double bar set up however lost interest or broke all of his sawzall blades ;) ;D ;D
I got it!
He wanted to carry a sheet of plywood home and figured that it would be nice to make a slot to hold it.
Also works as air brakes.;D
airman
Didn't Colt Seavers (the fall guy) have a sweet double bar set-up?
Seriously it looks like a full cage that had the middle cut out of it. You could probably pull the fron bar and mount it by the windshield and add the cross top bars for a full cage and not have to bend anything. Maybe add an oh shit bar.
Good luck with all of that 1/2" electrical tape. If that was here in AZ it would be a sticky gooey mess.
Jeff in AZ
BroncoKidd
Gainesville, FL
I cant beat that roll bar! When I get my body back up here at work I will take some pictures of what the last guy to touch mine did. He used 1 1/2" galvanized aluminum from a fence post and just welded it to the rusted out floor. The first weekend I worked on it I put my weight on it and it buckled right in two. There are some dumb people in the world.
lonesouth
lonesouth
Well, i found the answer to the question at hand...you guys won't believe this...He actually cut the roll bar so his soft top, looks like a jeep top, could fit better.
Skiddy
lol damn some people I swear, and it only took you a year to find out ;D
DonsBolt
Chestnut Hill, Mass
Wow what a hack
I have the same roll bar in mine, when I do a new cage you can have mine if you want.
lonesouth
lonesouth
I appreciate it, but i'm hoping to get one of the crab cages...if i can get it built with this cage's geometry...i.e. let me keep my tool box.
Buckin74
San Diego
Lonesouth
Hey --- here's how this works !!!!
The owner didn't want to build a stretched Bronco like everyone else. That's too easy .. Instead he shortened the rig soooooooo much ---- that the rear family cage met up with the front !!!!!!
This is obvious due to my many long -- um --- years -- um -- of experience -
STAR PLEASE !
lonesouth
lonesouth
What is the general consensus on what to do about the hack job? I could A. grind it down and leave it. Or B. grind it down and reweld in some tubing. Any of you cage gurus want to chime in as to whether the front and back bars tied together adds strength or just looks?
Don gets a gold star for having the same roll bar as me, HORRAY!
Bunkin gets a star for comedy of my miget bronco. Seriously, I want to see a shortened wheelbase bronco. Not mine, i want mine to be a crewcab, broncow i'll be callin in a few years.
DBrown
Bowling Green, KY
I would grind off the other welds and replace the pieces. not that hard of a job. and I could see the cage flexing at the other joint. while you are at it you could weld in a front cage kit and some frame ties to make it right.
I would also remove the wrap to see if there is anything else jacked up.
when I do mine I intend to put in seat holders to the cage and run a set of racing buckets in the front with 5 point harnesses. that way I don't really have to do the frame ties.
lonesouth
lonesouth
So...rough estimate of what it would cost for me to get a front cage built and installed with the rear roll bar, including seat mounts?
