- Nov 3, 2003
- 51,616
In a way, it's always timing related. But the amount of timing change that it takes to make a difference, and where your engine likes to run timing-wise, can depend on everything else around it still.
Such as, which cylinder heads and pistons you choose (combustion chamber shape and compression), which camshaft you use (dynamic compression and amount of fuel/air being introduced into the combustion chamber) and carburetor jetting (how lean or rich the mixture trying to burn is, and when, depending on jet size, metering rod profile, and spring tension) and all that.
So yes, it's absolutely timing related. But you can change that characteristic in many cases by how much fuel is coming in with the air.
With no other changes then, retarding timing is the go-to method for reducing pinging. Changing the timing curve can also change where your base timing is set, meaning you might not have to retard the timing as much to get it to stop pinging under different conditions.
