wild horses shorty headers
marty
massapequa, n.y.
was just wondering if anyone here is running their stainless shorty headers and how you like how the fit and are finished. how do they compare to others. i am planning a efi swap and was looking into a purchase in the future month or so. i was also wondering why the stainless setup was cheaper than the steel ceramic coated. engine is going to be a mild build.
thegreatjustino
Red Head Grease Monkey
Stockton, CA
I've been running the basic stainless ones for the last seven years. The fit is great. They drop right in and you can remove the starter without removing them. They have gotten somewhat discolored over the years due to the heat of the exhaust. Personally, I think they are the best headers on the market for the EB.
SHX669
We've got the ceramic version . The fit and quality are great. Assuming WHS is still using the JBA headers.
The ceramics are more money because they're --coated. More time/labor and material.
SHX
M
marty
massapequa, n.y.
ok that's what i was looking for thanks guys. just nice to be able to ask the guys that are actually running them what they thought. thanks again.
trailpsycho
The ceramic coated ones will also help keep your underhood temps down. The Ti-coated headers on the truck now run much cooler than the Ni-coated long tubes I had before. I would think that the SS ones would be more like the Ni-long tubes I had before temp-wise. Just something to thnk about.
gddyap
Mtn View, CA
If you're putting them on a 351W, it's a tight fit on passenger side. The header will make contact with the inner fenderwell and push it into the shock tower or coil mount. Can't remember which. Took me about 10 minutes to install the drivers side and 45 minutes to do the passenger.
