Wild horses shorty headers
ca pony
I have a 5.0 in my 75 ranger with duel exhaust and stock manifolds that the bronco came with. I've been thinking of putting on some shorty headers and I am seeking opinions on the matter. Since the bronco won't permit 5.0 stock shorty headers on the passanger side. I was thinking of buying some wild horses shorty headers. I was wondering, What brand are they? and if they are a good fit on the passanger side, as they claim? Also are there any other brands of shorty headers that are a good fit for the old bronco? Any help will be greatly appreciated. Thanks.
david heater
Westminster,Co
I'm not sure of the brand. But I have them in my 75 with my 5.0, the passenger side has about a 1/4" space between the colector and the frame.
I have no idea on hard they were to put in, I had the exhaust shop do it the same time they rebuilt my whole system. But they did no complain any when I picked it up..
mark74ranger
Albuquerque N.M.
The WH shorties are made by JBA. They are very high quality. I have the nickel plated ones and they still look great after 3+ years of daily driving. They have a very thick 1/2" I think flange and have never needed re-torqueing. A little more expensive than some of the other headers, but worth it IMO.
C
ca pony
Thanks for the info. I was leaning tord the wild horses shorty headers, now I am sure. Thanks again.
raharr3
Linden,Ca
What info?? Good or bad post it here to get the word out.
I can take some shots of the headers installed from the bottom if you want. The install was easy, dropped right in. Ill post the pic on here toinight if you want.
crawln68
74bronc said:
shoot me your email. I have some info you might be interested in about the JBA headers
byubronco@yahoo.com
Yeah, what is the information? I'm thinking of buying these too. Any information, good or bad would be greatly appriciated.
rob wilson
Flagstaff, AZ
I've got a set of the ceramic coated WH Shorties bolted up to a motor thats not installed yet if you need a pic, let me know.
bronco italiano
I would call Doug Thorley directly and get a set of the long tube equal length header he sells. First off you get the true long equal length tube torque, secondly it will work on an efi you just need to tig an o2 sensor bung (which you can put where you want for ease if install), thirdly I feel that Thorley has been around long enough and has the quality for less than JBA. Why pay 400$ for 5ft of tubing when you can get about 18 ft of tuned equal length tube that does a better job in the low rpm torque curve? Good luck BI
mark74ranger
Albuquerque N.M.
I always thought long tube headers weren't as good for low end torque, theus the tri-Y design on some.
Anyway. If you get the WH shorties, make sure to get the ones with the O2 bung installed. Even if you don't have EFI you can use the sensor with a voltmeter to tune your carb.
cbfomoco
WV
tell me some more on this please ;D
904Bronco
San Martin, CA
WH JBA shorty headers...
I thought I would just add my two cents... I have them on my 75, with an 88 EFI mustang motor. I am running an AOD, the passenger side is very tight. There is a square boss that is on the trans that you have to cut off at a 45 degree angle to get the header to fit right. Once you do that, the collector flange will be right on top of the trans bellhousing. There is a butt hair of space between the two. WH says the headers will work on all other applications, they do not do any AOD stuff, so I was the 1st one who informed them of an issue. They have worked well so far and I have a set JBA shortys on my 88 Mustang that have held up for ten yrs.
As far as what works and the cost... JBA makes a great quaility product, I think allot of the cost is because of the finish. I may have been around for a while, but I seem to remember that cast iron manifolds gave the best low end torque? It is all about what you want, ceramic finish is runs cooler (good for the engine compartment) and it seems to hold up over time (rust) vs paint. Some might say long tube are the way to go... I guess it is going to come down to what you are going to do with your rig, how things will fit, and how much $$$ you have. Buy the best you can afford with the money you got.
74bronc
OK, here's the deal. I was reluctant to post this article in a public forum because I wrote it specifically for Bronco Driver. We were holding the article for various reasons and I wanted to make sure it was OK with the mag before I posted it here. It is good information and I have wanted to get it out to the community for a long time. I did before and after dyno runs at JBA in San Diego during my header install. There is no way for me to post the actual graphs on this forum because the scanned imaged docs are 12.5mb. Included here is a MS Word doc of the article and a few of the pictures of the dyno tests and the install. I have tried to convert the article to PDF for those that don't have MS Word, but have been unsuccessful in finding a free converter program. Hope this info helps someone out.
Basically I love the JBA headers. They were a good choice for me. The construction is top notch and they have performed flawlessly for the 6 months that I have had them on there.
  • Headertecharticle.doc
crawln68
Great article. Thanks for the information. I will be buying a set. ;D
Mark
Bronco Klutz
NW Indiana
Good stuff,
and excellent timing for me as I am suddenly in the market for headers ;D
Hayburner
Port Orchard, WA
I'm running a set of JBAs on a 351w with Gt40 alum. heads, I trimed a little off of the rear of the pass. side fender well, as it just bairly touched, I went with shorties becouse I didnt want to have any issues with NV 4500 crossmember and Atlas 4.3 high Quality headers I'd buy them again for sure
