wild ride
kevin69bronco
Hey all ive got a 69 bronco... just got it running semi decent and took
it round the block..it has 2.5 lift on 33s...steering isnt bad but its friggin soft or maybe im just used to my silverado....can ya make it less touchy?
also where in the heck can I get a friggin timing pointer ... mine doesnt have one....without paying small fourtune?
TN1776
You won't get it to steer like your Silverado. How do you mean touchy? What kind of steering box do you have? The tight ratio boxes can be pretty touchy but all of them that I have driven feel a bit over-assisted on the street. My Silverado gives a bit more road feel and is more responsive than my Bronco - but you're comparing vehicles from very different eras. Silverado has better camber/caster and a more modern linkage setup.
R.P. Coltrane
Iowa, the flat part
Make a pointer. Mark TDC using a home made spark plug piston stop. Rotate engine forward and back by hand, marking stop points for wherever your home made pointer lands. Halfway between is TDC. Add permanent mark to the balancer and use a dial back timing light for settings other than zero.
good luck with your truck
K
kevin69bronco
Yea I get that.. And I guess I forget Ford had the one finger steering back then...is there a way to turn down power steering pump pressure? Would a steering dampner shock help?
jckkys
All the power steering in the '50s-'70s was very light compared to later vehicles. I guess they wanted to make sure you knew you had PS. Now most people take PS for granted and want more road feel. I'm surprised the after market hasn't offered internal parts to update the early gears. If you compare the Bronco PS to a '60s C20 the predecessor of the Silverado, you won't feel much difference.
K
kevin69bronco
I thought about looking on you tube on how to make one... orjust buying one...need to figure out correct depth for stop from spark plug hole to top of piston.
Not sure what you consider a small fortune Kevin, but we sell a stock EB pointer like this: http://www.wildhorses4x4.com/product/Timing_Marker
Of course, whether it works with your damper and timing cover is open to question if the engine is not from the EB originally, or has been modified in any other way, or has ever had the damper changed out and the incorrect one put in it's place.
Lots of variables I know, but maybe a nice close-up shot of the front driver's side area of your engine will tell the tale.
And tell us more about your suspension setup. Such as:
1. What suspension lift is installed?
2. What shocks are used?
3. What tires are installed, what is their exact size, type, age and condition, and what is the air pressure?
4. What width wheels and what offset/backspacing? If not sure, got pics?
5. What steering modifications, if any, were made to compensate for the lift if needed? Normally a 2.5" doesn't require what a 3.5 would, but it's still taller than stock ans some rigs are just more sensitive than others to this.
Good luck.
R.P. Coltrane
Iowa, the flat part
A home made piston stop doesn't have to be exact about length, it just has to be long enough to stop the piston. Weld or epoxy a bolt into the middle of a busted out spark plug.
This way will also tell you if there's a slipped inertia ring on the balancer. Pretty common when the vulcanizing that holds the halves is 40 years old.
good luck with your project
